AutoCAD for Mac General
Member
geoffreymbrown
Message 11 of 30 (8,884 Views)
Re: Tool and menu bar missing in autocad2011 mac
10-20-2010 01:11 PM in reply to: car2nhimu
I've been there
 ls -l Autodesk/
total 0
drwxrwxr-x  2 geobrown  staff  68 Oct 20 16:04 local
drwxrwxr-x  2 geobrown  staff  68 Oct 20 16:04 roaming
/Users/geobrown/Library/Application Support
drwxrwxr-x   4 geobrown  staff   136 Oct 20 16:04 Autodesk
New Member
Marimar21
Message 12 of 30 (8,790 Views)
10-28-2010 03:51 PM in reply to: geoffreymbrown
did you find a solution? i have the same problem and apparently nothing works for me
Member
geoffreymbrown
Message 13 of 30 (8,787 Views)
10-28-2010 04:43 PM in reply to: geoffreymbrown
Here are the directions I received from a tech support person
1. Open a terminal window.
2. cd "/Applications/Autodesk/
AutoCAD 2011/AutoCAD.app/Contents"
3. ./copyreg.sh  "/Applications/Autodesk/AutoCAD 2011/AutoCAD.app"
Note: The above assumes the default install location.
This did work for me, but I've had subsequent emails suggesting that they (autodesk) are
concerned that permission problems may persist.
What these directions do is
run a script distributed as part of Autocad that sets upn things in your ~/Library directory.
Nobody has said, but I'm assuming that when this script is ordinarily run (on my machine and maybe
yours) it doesn't have the right permissions to create the necessary files.
I don't know if this is universal, but our machines are set up so that installing
applications in /Application requires sudo.  Perhaps this is related to the root cause.
New Member
Marimar21
Message 14 of 30 (8,784 Views)
10-28-2010 05:01 PM in reply to: geoffreymbrown
well it works for me :smileyhappy: Thank you very much!!! :smileyvery-happy:
Member
yaronauto
Message 15 of 30 (8,476 Views)
Re: Tools icons missing in autocad2011 mac
12-22-2010 02:26 PM in reply to: geoffreymbrown
My tool set panel is empty . When I open autocad  I see at the commend bar :smileytongue:roblem loading cui panel:
I can use the draw ,modify. Dimension from the top bar , but I don't have it at the tool set panel .
Any ideas .?
thanx
maxim_k
Message 16 of 30 (8,459 Views)
12-23-2010 04:29 AM in reply to: yaronauto
have you tried this solution from geoffreymbrown?
Maxim
Architect
MARSS
MacACAD | MARSS
Member
yaronauto
Message 17 of 30 (8,421 Views)
12-25-2010 02:33 PM in reply to: geoffreymbrown
Hi . I have try that but  I think I am not writhing it right. Dose cd stand for the command baton on the keyboard? Do I need to use  the " at the beginning and at the end? Do I press the enter key between  the first command and the second ?
Can you tell me how to Wright it exactly?
Thank you for your help.
maxim_k
Message 18 of 30 (8,412 Views)
12-26-2010 10:04 AM in reply to: yaronauto
cd stands for Unix command "Change directory",
you have to open Terminal.app (in Utilities) and type exactly (with quotes):
first line
cd "/Applications/Autodesk/AutoCAD 2011/AutoCAD.app/Contents"      hit Return
second line
./copyreg.sh  "/Applications/Autodesk/AutoCAD 2011/AutoCAD.app"      hit Return
(don't miss point - first symbol in front of  /copyreg.sh)
Maxim
Architect
MARSS
MacACAD | MARSS
Member
yaronauto
Message 19 of 30 (8,397 Views)
Re: Tool and menu bar missing in autocad2011 Mac
12-27-2010 12:34 PM in reply to: geoffreymbrown
Hi . No it didn't work for me any  other suggestions?
Product Support
Message 20 of 30 (8,201 Views)
01-11-2011 11:24 AM in reply to: yaronauto
Spaces in unix are handled differently in Mac OS X.  Normally, you can add quotes to define the full path. i.e.
cd '/Applications/Autodesk 2011/Autodesk.app/Contents' but sometimes, this will not work.
It is much better to run the following commands to get your Tool Sets to work:
cd /Applications/Autodesk\ 2011/AutoCAD.app/Contents
./copyreg.sh /Applications/Autodesk/AutoCAD\ 2011/AutoCAD.app
The space in the Finder is replaced with "\ ".  [Backslash + Space]
David Lau
You are not logged in.
Ask the Community
