Does anyone know of a shortcut to toggle through ISOPLANE when using isometric snap?
From memory I think it used to be Ctrl+R in the windows version.
I can't seem to get anthing to work other than actually typing in ISOPLANE and selecting either Top, Left or Right
Solved by khedeks. Go to Solution.
Hi John,
You should be able to use F5 (or Fn+F5 depending on your settings) to toggle ISOPLANE.
Shekhar Khedekar
I had to actually go in and deactivate "spaces" from F5 with keyboard preferences to allow this to happen though
Fn+F5 should work if you have F5 set to spaces. In the Keyboard section of system preferences you can also use all F-keys as standard function keys, and use Fn+F5 for spaces.
Shekhar Khedekar
When spaces is activated it activates when both F5 or Fn+F5 are pressed........unless I am missing something else.
Welcome to the Autodesk Forums!
Do you enable "Use all F1, F2 etc. keys as standard function keys" in Keyboard pane of Mac OS System preferences?
Maxim
Welcome to Autodesk Forums!
Hi @parthsinghal02 ,
@parthsinghal02 wrote:
Is there any other way to toggle isoplane except for fn-F5 ?
Yes, if you are using AutoCAD 2022, you can assign shortcut to "Toggle Isoplane" macro and then use it to toggle isoplane:
