AutoCAD for Mac General
Message 1 of 9 (6,375 Views)
Scale factor - autocad 2013
6375 Views, 8 Replies
12-27-2012 05:31 AM
Hiya. I've been working on a drawing autocad for mac 2013.
I want to scale my drawing by 2. Every time I try it acts as if it has worked, but the physical size hasn't changed at all. At first I thought it might need a larger scale factor to see the difference, but no matter what the value (even 0.5), the dimensions aren't changing.
Does anyone have any ideas what's going on? I've used the programme to scale before and it has worked. I also tried the drawing on another computer, but it made no difference
maxim_k
Message 2 of 9 (6,366 Views)
Re: Scale factor - autocad 2013
12-27-2012 07:05 AM in reply to: 09165021
Please clarify how do you scale drawing? Do you use SCALE command? Or you just change scale for annotations on the Status Bar?
Maxim
Architect
MARSS
MacACAD | MARSS
Message 3 of 9 (6,351 Views)
12-28-2012 07:31 AM in reply to: 09165021
I type sc, press enter, click a base point and type the value. It is working for other drawings, just not his one
maxim_k
Message 4 of 9 (6,344 Views)
12-28-2012 10:58 AM in reply to: 09165021
How about selecting objects you want to scale? Or you scale whole drawing?
Could you post your drawing here? Or send me to mkanaev at tandem.ru ?
Maxim
Architect
MARSS
MacACAD | MARSS
Message 5 of 9 (6,244 Views)
01-07-2013 07:34 AM in reply to: maxim_k
I'll send you the drawing.
it's part of a larger drawing, but this is what I need to scale:
maxim_k
Message 6 of 9 (6,235 Views)
01-07-2013 11:06 AM in reply to: 09165021
Almost all of objects in your drawing are constrained with each other (parametric constraints feature). So when you try to scale all objects in this drawing you (as I) should get this at the command prompt:
Command: SC
SCALE
Select objects: Specify opposite corner: 268 found
Select objects:
Specify base point:
Specify scale factor or [Copy/Reference]: 2
One or more constrained objects cannot be resolved.
In order to see all constraints you have to select "Constraint bars -> Show all" from Parametric menu.
In attached file I deleted all constraints, an now it is "scalable".
Maxim
Architect
MARSS
MacACAD | MARSS
Message 7 of 9 (6,229 Views)
01-07-2013 12:59 PM in reply to: maxim_k
Thanks a lot..it's perfect.
What did you do to delete all the constraints though? I went into parametrics, constraints bar, show all, but nothing changed on my drawing.
In fact, I don't even know what constraints are I'm afraid
maxim_k
Message 8 of 9 (6,220 Views)
01-07-2013 08:57 PM in reply to: 09165021
If you did this with drawing I've send to you - then there are no constraints in it, I already deleted them all.
If you will try to "Show all constraints" in your original drawing, then you should see:
You can start to learn about Parametric Constraints in AutoCAD Help here:
http://docs.autodesk.com/ACDMAC/2013/ENU/filesAUGMac/GUID-F873DE3A-0F12-4A58-B35E-0BC5C98A7F35.htm
Maxim
Architect
MARSS
MacACAD | MARSS
Message 9 of 9 (6,178 Views)
01-15-2013 06:07 PM in reply to: maxim_k
I type "scale", then enter, choose a base point and then type the value Saskia
You are not logged in.
Ask the Community
