AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Saving Blocks? how to create a block floder
7 REPLIES 7
Message 1 of 8
ageyreader
2071 Views, 7 Replies
Hi
I would like to create a block from an existing drawing and put it into a new drawing. When I come to insert it into a completely new drawing its not there, how do I do this please? How do I save blocks into a folder, to keep everything organised? Working on Macbook Pro with AutoCAD 14. Most gratful for you help.
ageyreader
Tags (2)
7 REPLIES 7
Message 2 of 8
maxim_k
in reply to: ageyreader
Welcome to the Autodesk Forums!
On Mac you can use traditional method - WBLOCK command to create block from:
  • Block
  • Entire Drawing
  • Objects
At the top left of dialog you need to pick on "Change" button and navigate to the folder where you want store blocks.
Another mot hod on Mac is to create as many blocks as you need in one drawing, save this drawing to the some folder on your Mac, than use "Content palette" to add this drawing to an existing Library or to the new Library. You need to add it with option "This drawing contains multiple blocks" when prompted.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 8
ageyreader
in reply to: maxim_k
Thank you, that has been really helpful, I now have a specific part of an existing drawing into a new drawing.
My next question is how do I insert a title block and create a new view port? To enable me to scale and print.
Message 4 of 8
maxim_k
Switch to Layout, use Page setup manager to set the size of the sheet, than insert title block in Paper space, than create as many viewports as you need with "New Viewport" button on Paper space Visor (you will see when you are in Layout), than select viewport and set scale for it with Status Bar, or Properties palette.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 8
ageyreader
Thank you again, when opening the Auto CAD, I have been opening acad.dwt and have struggled to insert blocks and view ports.
I should have opened Tutorial-iArch.dwt. These steps that you have produced have been really helpful and will allow me to progress, so deserved Kudo!!!
Message 6 of 8
ageyreader
So I can insert a title block and create a new view port,
Is there a way to insert a block and size it, by dragging it out and it to fit onto my sheet?
Tags (2)
Message 7 of 8
maxim_k
You need to use specific title block for each sheet size, so after you set paper size for Layout, you need to insert specific title block for this paper size.
If you really need to scale title block you can do this with SCALE command with Reference option in it.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 8
justshutup
You need to just take a class.
”Boost
