I have an issue with rendering. It seems as I can't change the style of Rendering for example, the default is Linear, but when I switch to another style, such as Curved, the object is still colors as Linear. How do I change different rendering styles?
Linear, Curved are various styles of Gradient icon. I need to color an elevation of an interior, so when I try to select a pattern from Gradient icon, it doesn't change the style.
With Hatch it works just fine to change the patterns. But, when I use Rendering option to change to a different style, the default stays at Linear style.
I don't know why you write about "Rendering" if you mean in fact Gradient fill option of hatch (or GRADIENT command). In my case, when I call GRADIENT command and pick "Pattern" (Gradient) swatch - Hatch Library palette opens and I can select the type of gradient fill from there (Linear, Curved, Spherical, etc.) and the swatch changes to the fill type I selected.
Maxim
