I'm finding a few issues when using SPACE as the enter
For expample when I go to copy something I will;
COPY (space) - Select an object (space)
The second space seems to cancel the command instead of moving on to ask for basepoint or displacement
It only does this intermittantly and I can work around it by using Rightclick on the mouse instead of (space) after I select the object(s)
Is this a common issue?
Solved by JohnRennie. Go to Solution.
Following some help from Auotdesk I had to reset the SUBOBJSELECTIONMODE to 0, and SELECTIONCYCLING to 0.
this fixed my problem.
