Every time I go to print, CAD crashes.
I can get to the page setup ok, but then when I go to print it just dies. Dialogue doesn't even come up.
Also not being able to print to file (IE PDF or EPS) is a big problem, as is editing CTB files- are these features coming soon?
Same for recovery manager. Thanks to autosave not seeming to work even though it says its on and this print issue, I just lost a couple hours worth of work
Tried reinstalling- no help, even after deleting all support files.
Also about every other time i try to print now my whole computer freezes a minute later and has to be restarted. doesnt even give me the option of sending an error report. plz to help! anyone else have this issue or a wrokaround?
could this be because my specs are low on the recommended list? Or a graphics thing?
Model Name: MacBook
Model Identifier: MacBook5,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 3 MB
Memory: 2 GB
Bus Speed: 1.07 GHz
NVIDIA GeForce 9400M
Please help I've crashed/frozen my computer 4 more times this morning trying different ideas.
Basicallyu as soon as i select file->print or hit apple-p I get a spinning rainbow for 10 seconds followed by autocad crashing, then 5 seconds later the whole computer freezes.
Actually, this system does not meet the minimum requirements. You need at least 3GB of RAM.
Hi ddvrom,
1. What kind of printers you have on your system? Which is default printer?
2. The file you are trying to print was created in AutoCAD for MAC or in Windows version. If in Windows - is there any print settings this file (I mean some Page setup)?
Maxim
Thanks for the replies- I thought maybe it was a RAM issue then and I just recently upgraded to 4gb of ram so I meet the requirements- sadly the problem is still happening.
It won't even load the print dialogue box, it just gives me a spinning rainbow for a few seconds and then AutoCAD crashes- and then every other time I try it the whole computer freezes.
TO answer your questions-
1.) I want to use a networked printer- the only printers on my machine are that and a PDF printer- a thing will coem up saying the defalut printer (a PDF one) is not usable and I click ok- then it crashes.
2.) It doesnt matter- at first i thought this too but even if I just open the program and draw a quick box or something in a new file and then go to file print, the same thing happens.
Any help greatly appreciated! I really want to get rid of my virtual machine and just run natively!!
Have you tried to set one of your networked printers as default printer in System Prefs -> Print & Fax -> Default printer, (instead of PDF printer)? Or even (temporarily) remove the PDF printer from system?
And what about printing from another application?
Maxim
So sometimes now, it works. But mostly it does the same thing. I have tried messing with the default printer setup (I CAN get into the page setup menu, its just the print command itself that doesnt work).
For example yesterday I probably pirnted about 10 times in a row, but today now it has crashed every time I tried.
and to answer your question I don't have this issue in any other programs, I can even print totally fine through autocad in parallels.
I have a similar problem.
just after i hit cmd+p
i see a warning:
Adobe PDF: This plotter configuration cannot be used for one of these reasons: the driver cannot be found, the device cannot be found, or the driver has a problem. The default plot device has been substituted.
i click ok and continue, get the page setup, choose right printer and paper size.
when i hit ok, i get this error:
There was an error saving the file /Users/xx/Library/Application Support/Autodesk/roaming/AutoCAD 2011/R18.1/enu/plotters//HEWLETT_PACKARD_DESKJET_930C(temp).PCM
afterwards autocad freezes, i can click ok endless amount of times with no result and have to force quit.
i have tried this with different printers and file... all the same...
also saving as PDF doesn't work for me.
can someone help me solve this problem?
Hi a.m.molenda,
I think it is permissions problem.
Try to change "Printer configuration Search Path" in Application Prefs:
to something other, then you have by default, for example to your Documents folder.
(when you click on OK or on Preview in print dialog, temporary PCM file created in this folder)
HTH
Maxim
Did you apply the AutoCAD 2011 for Mac Update1 ? Do you see the same printing error after applying the update?
thank you,
Pavan Jella
AutoCAD Test Development
Autodesk Inc
thanks maxim and pavanjella!
changing the paths already helped, somehow they were tweaked and thus missing the right address.
i installed the update only after your advice.
everything works well now.
many thanks for your help!
I use AutoCAD 2011 on a 15" MacBook Pro. My CAD was having the same problem of freezing and crashing when trying to turn into PDF and print. After repetitive tries I force quit. When I went to open it again it would not and shows this error message:
Error Signature
Application: AtutoCAD
Version: E.49.H.62(x64)
Error: Unhandled Exception
The error report contains the following files:
crashLog.txt
dmpuserinfo.xml
dumpdata.zip
system_profile.xml
WHAT DO I DO??
If you have a problem with an alert about "error saving .PCM file" - Could you post screenshot of Printer configuration search path in Application Preferences?
Maxim
Maxim,
Thank you! I followed an old thread you posted and rerouted the printer through the "preferences>applications" menu. Whew! I have done the updates as well and everything is printing fine. If I was there right now I would give you a big hug!!
THX
Hello maxim_k!
I am having the exact same problem as a.m.molenda . I do not understand what I am supposed to do after I open preferences > applications > printer support file path > printer configuration search path.
What am I supposed to click on after this point?
Thanks so much !!
hi maxim
i tried all the ways you sugessted ,changed paths ,updated the software.. nothing new i'm really depressed
i can print using any program but atocad
i tried the versions 2011,2013,2014.. i still have the same prob.
plz help
