I've both the 'magic mouse' for my mac and since I've been having troubles finding out, how 'pan' with it.
With my old mouse, I could push the scroll-roll down, and this would active the 'pan' option automatically, when I would release the scroll-roll - the 'pan' would deactive. With this 'magic mouse' I can only activate the pan when going to File / Pan or using a little 'hand' icon, placed next to comand line. That makes a long jorney, when I need to navigate between drawing and paning.
Is there any easier way to 'pan' with 'magic mouse'?
P.S I work with AutoCAD 2012 for Mac.
Regards
Vilma
Solved by maxim_k. Go to Solution.
Hi Vilma,
there are a lot of ways to pan with magic mouse in AutoCAD for Mac:
1. You can enable "middle" mouse button with free MagicPrefs application and use it for pan as with ordinary mouse.
2. You can use Spacebar to pan - just hold it down and move mouse, pick and drag with left side "button" of mouse to pan further
3. Scroll on mouse surface with Alt (Option) key pressed to pan around.
Maxim
Hi Maxim, I am still having issues with the Pan command in AutoCAD 2014 for Mac. I'm using a logitech mouse, but the problem is still the same- the pan command stalls out if I use the middle scroll button on my mouse, type in the pan command, or click on the pan tool- please help!
Could you tell me how to activate the pan Command in Autocad 2018 in Magic prefs Application so that it pans when I scroll on my Magic Mouse instead of zooming?
