AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
PRESSPULL Not working?!
8 REPLIES 8
Message 1 of 9
Codyslarks
18488 Views, 8 Replies
As anyone else had a problem with the presspull command on the 2011 autocad for mac? If so, can you help?? I have a school kitchen project due soon and I need to be able to work on it from home also
8 REPLIES 8
Message 2 of 9
maxim_k
in reply to: Codyslarks
Yeah, it seems, no problem with PRESSPULL command. It works for me. What's your problem?
1528iC70B3B8B48E24AE6
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 9
Codyslarks
Hmm, I don't know what the problem could be. When i go to use the command, its not detecting the boundaries at all. I am able to use AutoCad 2009 at school on a PC and its works fine. On my 2011 MAC edition I do not get the dotted line for the boundary it detects. I'm not able to use the function at all. Have any suggestions?
Message 4 of 9
maxim_k
Hi ,
I think, I got your problem:
in the command prompt type SELECTIONPREVIEW, type 3 and hit Return:
Command: SELECTIONPREVIEW
Enter new value for SELECTIONPREVIEW <0>: 3
Command:
It should work now.
From HELP:
 SELECTIONPREVIEW variable
Type:Bitcode
Saved in:Registry
Initial value:3
Controls the display of selection previewing.
Objects are highlighted when the pickbox cursor rolls over them. This selection previewing indicates that the object would be selected if you clicked. The setting is stored as a bitcode using the sum of the following values:
0
Off
1
On when no commands are active
2
On when a command prompts for object selection
I have noticed, that sometimes value of this variable resets to 0
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 9
Codyslarks
Thanks!!! I've got to give it to you! You know your stuff!! Thanks so much!!
Message 6 of 9
maxim_k
You are welcome!
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 9
carterth
Worked for me also. Thanks so much.
Message 8 of 9
vrunda.bante99
in reply to: maxim_k
While I am selecting the presspull command it is going in buffering status for long time. Can u help me with this please.
Message 9 of 9
maxim_k
in reply to: vrunda.bante99
Welcome to Autodesk Forums!
Hi @vrunda.bante99 ,
Do you use PRESSPULL in a complex drawing?
AutoCAD needs to calculate bounded area for creating the extrusion with PRESSPULL and this can take a significant amount of time in complex drawings and on a computer with an insufficiently fast processor.
You can try temporary turn off unnecessary layers and hide unnecessary objects before using PRESSPULL.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
