AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
PDF export issues
11 REPLIES 11
Message 1 of 12
rgwhatley
623 Views, 11 Replies
PDF export issues
Whenever I export pdfs, the lines randomly move position, size, change weight or disappear, particularly curves. Can some tell me if there's a way around this problem? Images attached thanks.
11 REPLIES 11
Message 2 of 12
maxim_k
in reply to: rgwhatley
It appears that your print settings wrong somewhere. But I can not say anything without having original DWG.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 12
rgwhatley
in reply to: maxim_k
Do you mean the actual DWG or a screen shot? I haven't changed the print settings since installation. Screenshots of the original drawing in Autocad attached:
Message 4 of 12
maxim_k
Of course, I mean original DWG.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 12
rgwhatley
I've just emailed it
Message 6 of 12
maxim_k
Look for my results in attachment. I think they are exactly like in DWG.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 12
rgwhatley
Thanks, could I ask how you exported it? And do oyou have any ideas whats wrong with my autocad?
Message 8 of 12
maxim_k
Nothing special.
I have HP DesignJet 450 plotter (Gutenprint drivers) configured on my Mac. You can search my posts here on Forums about configuration details.
In AutoCAD I just make Page setup (paper size, what to plot, scale, etc.) and either batch publish to PDF or simply open PDF in Preview and save PDF there.
What plotter (printer) do you have on your Mac?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 12
rgwhatley
I don't actually have a plotter personally, I tend to use one of the university printers so don't print from autocad, usually I export the pdf to illustrator for presentation layout first. I just export pdf's by file-export-pdf-display/extents. If tried exporting via layout manager - same issues though.
Message 10 of 12
maxim_k
So you want to say that you have no System printers on your Mac.
Have you tried my suggestion about installing Gutenprint drivers?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 12
rgwhatley
Yes thats right. I do have a standard canon a4 printer with drivers installed though.
Message 12 of 12
maxim_k
So my strong advice is to install Gutenprint driver, add one of the plotters supported by Gutenprint driver (as I wrote before, I use HP DesignJet 450 model), and use it when you output to PDF from AutoCAD.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
