This may or may not be a dumb question but for some strange reason all the lines I draw turn into elongated parallelograms. I'm not sure what I did wrong or if I did anything to do this, but I need to get this fixed so I can get on with my project. Please tell me what to do!
I've attached a screenshot.
I have tried restarting AutoCAD to no avail.
Thanks for all your help!
Jonathan Chan
Solved by maxim_k. Go to Solution.
Hey Maxim,
I used the default line command and the poly line command but both did the same thing.
I've attached the DWG file.
The lines I've drawn as the example are the two turqoise lines between the two main floor plans, the left one a normal LINE and the right one is the PLINE.
Thank you very much for your help!
Maxim,
Oh my gosh you are a GENIUS. THANK YOU SO MUCH YOU HAVE SAVED MY PROJECT!!!
I haven't used AutoCAD for a year and a half and I've had to dig it all back up to do this studio design project and I know nothing about troubleshooting in CAD so THANK YOU VERY MUCH!!!
God Bless,
Jonathan Chan
