AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Lines turn into parallelograms
4 REPLIES 4
jonchanzc
1529 Views, 4 Replies
This may or may not be a dumb question but for some strange reason all the lines I draw turn into elongated parallelograms. I'm not sure what I did wrong or if I did anything to do this, but I need to get this fixed so I can get on with my project. Please tell me what to do!
I've attached a screenshot.
I have tried restarting AutoCAD to no avail.
Thanks for all your help!
Jonathan Chan
4 REPLIES 4
maxim_k
in reply to: jonchanzc
Welcome to Autodesk Forums!
Hi Jonathan,
Do you use LINE command?
What if you try to draw polyline (PLINE command)?
Could you post here your DWG file with such lines?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
jonchanzc
in reply to: maxim_k
Hey Maxim,
I used the default line command and the poly line command but both did the same thing.
I've attached the DWG file.
The lines I've drawn as the example are the two turqoise lines between the two main floor plans, the left one a normal LINE and the right one is the PLINE.
Thank you very much for your help!
maxim_k
At first, I have to say that view in your drawing is not perpendicular to the World coordinate system (WCS) plane you are working in.
So the first thing you need to do - start PLAN command and hit Return two times.
The view is now correct, but at first moment you can think that drawing is empty - that is because of the second thing - if you will look to the upper right corner of the screen - you will see small black dot (or white, if you have black display color). You need to delete it - that is piano block, that accidentally "flew away" from your main drawing area.
After you delete it you can ZOOM ALL - now lines seems to look normal, but wait - that is not all.
Type word THICKNESS at the command prompt (the name of the system variable) - you will get :
"Enter new value for THICKNESS <2'-6 1/4">:"
Type 0 (zero) and hit Return. This will set thickness in your drawing to 0 (zero) - default value. Now all lines you will draw will be "flat".
They appeared as parallelograms because they had a thickness and your view was not perpendicular to the drawing plan.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
jonchanzc
Maxim,
Oh my gosh you are a GENIUS. THANK YOU SO MUCH YOU HAVE SAVED MY PROJECT!!!
I haven't used AutoCAD for a year and a half and I've had to dig it all back up to do this studio design project and I know nothing about troubleshooting in CAD so THANK YOU VERY MUCH!!!
God Bless,
Jonathan Chan
”Boost
