Hi there,
I'm using AutoCAD 2014 for Mac. I'm drawing a detail which contains different lineweights and they show correctly in model space, but in layout all the lineweights show up with the same thickness. I've tried many things and apparently I changed something in one of my layouts which causes to show it correctly now, but I have no clue what I've done In my other layouts it still shows the thickness wrong. Anyone got an idea how to change these settings?
Thanks in advance,
Arnoud.
Hi, thanks for the quick respond.
I've assigned the lineweights individually for each object. I've tried the "remove viewport overrides for all layers", but nothing changed. I'll explain my problem with some screenshots of one of my drawings.
First my drawing in Model, as you can see the lineweights are shown correct (0.25mm).
This is the same drawing shown in layout, which at first sight looks good as well.
But then when I zoom in, the lineweights also become thicker.
And then the final screenshot, a print preview, which also shows thicker lineweights than originally drawn. (Also the drawing shows a bit gray, any idea how to fix that to black?)
I think it has something to do with 'linescale', but I'm not sure.
Thanks for helping,
Arnoud.
