I have been searching the web and have been finding mixed resposes... Does Layer States or Layer States Manager exist in AutoCad LT 2013 for MAC?
When I type it into the command bar it comes back as unknow... When I type it into the search command it doesn't find it.
Is it now called something different? if it doesn't exist, is there another way to acheive (creating certain grouping of layers that will "turn on" and "turn off" only in certain situations) using another command or tool?
Thanks!
Solved by maxim_k. Go to Solution.
Hi ART,
I think the best explanations regarding your issues with layer states in Model and in Paperspace (inside viewports in Layout) already done by Alfred NESWADBA in this topic:
“Locking” the layers state in the viewport
In other words you have to distinguish the difference between Global layer properties and Viewport (VP) layer properties and use them when you create Layer states for viewports and changing something in layer settings in Model space afterwards.
Maxim
Hi Maxim,
I looked at the Alfred NESWADBA post on this topic:
It essentially suggests what I had mused was a possible option in my previous post
"I guess that I could just bring up the layer control window in each viewport, and brute force VP freeze the layers I don't want on (and have a layer state resotred in model space with all layers on and unfrozen). But that isn't very elegant and is pretty time consuming"
However, I would hope that there is a solution to this that involves the power of the Layer Manager. Otherwise one has to repeat over and over again the selection of VP layer freezing for each layer (one at a time), for each viewport in all the Layouts (though once you have done this for each viewport, you are indeed good to go). Is it possible to create a saved Layer state that has some state of VP layer freeze settings, go into a new viewport, apply that Layer state (in order to get close to what one might want for VP settings), and then tweeak the VP freeze layer settings?
For example, one could have a VP Layer freeze setting state for "sections" that would be a good first step (though not exactly what I want) for all my section viewports. After applying it with the viewport active, I would then go in a tweak the invididual settings of VP layer freeze for just a handful of layers and arrive at what I want for that viewport.
thanks,
ART
What a f'ing heachache this is!
How do I export my layer states and import them into another drawing. I went through all the prompts only to not know where it exported the file!
For those of you like me frustrated by this.
the .LAS file save to the follwing folder...
/Users/Username/Documents
