AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
LT 2013 Pan Tool Delay
2 REPLIES 2
466 Views, 2 Replies
Can anyone explain the two to three second delay I experience in AutocadLT 2013 for mac when I hold down the spacebar to acquire the pan tool? Is there a way to make the pan tool appear immediately upon pressing the space bar? Or is there another keyboard shortcut I can use for pan that will eliminate the delay?
2 REPLIES 2
maxim_k
HI,
if you are not inside some command, you can type P and hit Return (or Spacebar) to call PAN command.
Inside command you can use middle mouse button to pan transparency,
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: maxim_k
Maxim,
Appreciate your time. This (and your response to my onsnap issue) were both spot on.
Cheers
Jeff
”Boost
