I am having an issue with printing after updating to SP2 on my Mac version. I am running OSX Mavericks and version G.55.M.208. The issues I have are when I click "Print" and set it up with my plotter that was working it does nothing. It doesn't even attempt to plot the layout.
The second and separate (at least it seems to be) is when using batch publish, the PDFs or plots no longer match the layout 100%. There will be random layers (not set to not plot and also not set to freeze or vp freeze) that just choose to not plot. This is frustrating as it slows down production as I never know what I will get when I plot to PDF or to my plotter.
HELP! Thanks in advance!
We have the HP T520 36". I can print to it from other programs on the mac using the print dialog. I can also print to it via the batch publish option, but some layers seem to not plot.
It seems to be the same layers if I batch publish several times, however its not always the same layer or type of layer (such as a xref doc layer, etc) across files. It also can change which layer it chooses not to show if I close the application and reopen.
It's the weirdest problem I've ever come across.
These files are also in a folder on my desktop currently. I was originally editing over an afp share, but wondered if that caused an issue, so I copied the entire drafting folder to the local drive - all xrefs are always attached with relative path so that when a file/folder gets zipped, it can be transported.
OK. That got me a lot closer.... seems as for some reason the print dialog in AutoCAD does not like the driver for our plotter. When I tried selecting just a regular laser printer and printing to PDF, it seems to have worked - and showed what appears to be all the layers (at least at a quick cursury glance.
Still baffling why it seemed to coincide with the updating to the Autocad LT 2013 MAC SP2 install....
I will try to re-install my plotter drivers and report back on here.
OK. So, after uninstalling and re-installing the driver and plotter, I have the same issue. I can freely print from any other program on the Mac, but cannot "Print" either to the plotter or to PDF with the plotter selected as the printer driver.
Any other thoughts? I did make sure to download the latest driver from HP.
