Hey there,
I am using AutoCAD for Mac and I often need to draw standard parts like screws, bearings and so on.
Is there a possibility to export the part library from AutoCAD mechanical for Win and include it into the Mac Version?
Thanks for your help.
Yes, we do not have content library in AutoCAD for Mac. But I see the Contetn Palette may be able to help you work more efficiently. You can import the blocks from other drawings into the Content Palette. Then you can access to these blocks via the Content palette easily. You can also save a templete after importing the blocks.
Wei
Thanks for your answer.
This means I have to draw each part first, before I can include it into my content library?
Is there no possibilty to import an existing content library?
Greetings
