AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Importing SolidWorks 2008
5 REPLIES 5
tlbtlbtlb
966 Views, 5 Replies
I'd like to switch from SolidWorks to Autocad, mainly so I can run on Mac. However, I am baffled at importing SolidWorks files. I'm using Autocad 2013 on Mac.
I click File / Import, choose a .SLDPRT file made by Solidworks 2008, and nothing happens. I don't see an import progress icon or error message or anything. I'm following the procedure described here:
http://exchange.autodesk.com/autocad/enu/online-help/ACD/2012/ENU/pages/WS1a9193826455f5ff4ae1cb4e12...
I've tried with several different parts, both small and large. Attached is one of many that didn't work.
Tags (1)
5 REPLIES 5
maxim_k
in reply to: tlbtlbtlb
The instructions are for Windows version of AutoCAD 2012. In Mac version of AutoCAD you can only import .SAT files (and, of course, open DWG, DXF , DWT files)
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
tlbtlbtlb
in reply to: maxim_k
It'd be super-helpful if the software gave some kind of error message, rather than just doing nothing.
Should I be able to use a WIndows version to do the conversion, then edit the 3D .dwg files on a Mac?
Are there a lot of other things the Mac version doesn't do? The faq (http://images.autodesk.com/adsk/files/autocad_2013_faq_en.pdf) doesn't admit to any.
maxim_k
Are there a lot of other things the Mac version doesn't do? ...
1. I think - yes, you can
2. About differences - look here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15833488&linkID=15839490
HTH
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
I too am unable to import from Solidworks (unsure which year/version) to AutoCAD 20213. I am on a windows 7 machine, and I get the same "nothing" that the original poster got.
We acquired a company that had everything drawn up in Solidworks. We, however, just recently purchased AutoCAD and do not want to spend money on Solidworks. I need to be able to import Solidworks in to AutoCAD. How do I do that?
Thank you.
maxim_k
If you are running windows 7 machine, I can assume that you are using AutoCAD for Windows. So why are you posting here, in AutoCAD for Mac Forum?
Anyway, I think that AC 2013 can import SolidWorks files. I tried to import SolidWorks file attached to the first post in this topic and was able to do this in AC 2012 for Windows.
After you choose SolidWorks file to import you have to wait until importing operation is complete, you should be notified via AutoCAD notification center.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
