After hiding some objects to make easy to work, it's not possible to make them visible again. "End Object Isolation" doesn't work (or maybe it's not right way). How can I show hidden objects again?
As you can see only one of the hidden objects (on the bottom left corner) is visible.
Solved by maxim_k. Go to Solution.
There should be an objects, but after hiding they disappeared. I also attach the DWG file, please find the attached file below.
Here how it looks when I select visible object that was in the same Group with "hidden" objects:
It appears all (exc 2) 3D Solids in your drawings has zero height somehow.
I give them positive height and they reappears
Maxim
Sorry, I didn't understand. What you mean with "zero height"? How it could be? Everything was nice enough before.
The reason why I ask is to understand why after hiding and ending isolation only one of the objects is visible properly.
