Solved by maxim_k. Go to Solution.
In a situation you described, you are creating SURFACE object with EXTRUDE command.
You control number of isolines for newly created surfaces by setting values of system variables SURFU and SURFV (if you set them to 0 (zero) you will get the result you want)
As you create SURFACES, then DELOBJ system variable depends on SURFACEASSOCIATIVITY variable, you have to set it to 0 (zero) and set DELOBJ=3 in order to delete original 2D object during surface creation.
All these system variables (except DELOBJ) saved in drawing file, i.e. you have to set them in each new drawing, or save settings in template file.
Maxim
