Show only
Search instead for
If you want to be able to change color of block (when it is inserted in drawing) you have to change color of the objects to "BYBLOCK" value. You can do this inside block editor- select objects and in Properties palette change the color to BYBLOCK. Don't forget to create block from objects placed to layer "0"
Maxim
Do you find the posts helpful? "LIKE" these posts! Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
