my cursor and screen jumps/moves away everytime when I single click on to hatch or use the hatch command it also does the same with text. So I have to find the hatch back when edting.
Can anyone please help?
Thank you.
Solved by maxim_k. Go to Solution.
yes, exactly. I click on hatch and it moves away from hatch pattern, its very annoying because I have to find drawing back everytime i do this. It only occurs with hatches and when I'm overwriting text.
Second. It shifts the view.
In the command line it doesn't say anything. Say for example I want to stretch hatch so I click on it and the whole MSPACE shifts somewhere. It occurs also when I just type H (hatch command) but it doesn't do it when I change HPDLGMODE to 1 then the windows pops up and the drawing stays still.
I really don't know what it is now I have it in all drawings I was thinking it can be related when I was installing some of the hatches but then it started doing later...
thank you for your help, I have spend two days searching for reason why this is happening but no luck.
I'm working in model space.
yes, I tried restart it and remove new hatch pattern it has been happening for two weeks now.
I just tried another thing...I opened same drawing on MacBook with same hatches installed and drawing stay still its allright.
So its something in iMac, some settings...I have no idea.
So by Resetting Application settings from Application tab of AutoCAD settings all is good. It worked. I forgot to do screenshot before I did the Reset but I did one after:) and noticed one thing, the hatch editor or viser on top of the screen is now nice in the middle but before it was on right side so I couldn't se the end of it (I never notice until now) so I was thinking maybe the whole window was somehow shifted...And when I click on hatch it tried to get closer to hatch editor....
