AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Hatch problem
8 REPLIES 8
Message 1 of 9
Bramborik
450 Views, 8 Replies
Hatch problem
my cursor and screen jumps/moves away everytime when I single click on to hatch or use the hatch command it also does the same with text. So I have to find the hatch back when edting.
Can anyone please help?
Thank you.
8 REPLIES 8
Message 2 of 9
maxim_k
in reply to: Bramborik
You just pick a hatch and crosshairs go away from drawing window? An I right?
Strange behavior...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 9
Bramborik
in reply to: maxim_k
yes, exactly. I click on hatch and it moves away from hatch pattern, its very annoying because I have to find drawing back everytime i do this. It only occurs with hatches and when I'm overwriting text.
Message 4 of 9
maxim_k
Where do you have to find drawing? On Mac desktop? Or you mean that AutoCaD changes current view ( different zoom level or pan)?
If second- what do you see in Command window?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 9
Bramborik
Second. It shifts the view.
In the command line it doesn't say anything. Say for example I want to stretch hatch so I click on it and the whole MSPACE shifts somewhere. It occurs also when I just type H (hatch command) but it doesn't do it when I change HPDLGMODE to 1 then the windows pops up and the drawing stays still.
I really don't know what it is now I have it in all drawings I was thinking it can be related when I was installing some of the hatches but then it started doing later...
Message 6 of 9
maxim_k
Are you working in Model space or in Layout?
Have you tried to restart AutoCAD (AutoCAD->Quit AutoCAD)? Remove new hatch patterns?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 9
Bramborik
thank you for your help, I have spend two days searching for reason why this is happening but no luck.
I'm working in model space.
yes, I tried restart it and remove new hatch pattern it has been happening for two weeks now.
I just tried another thing...I opened same drawing on MacBook with same hatches installed and drawing stay still its allright.
So its something in iMac, some settings...I have no idea.
Message 8 of 9
maxim_k
The only one solution I see here is try to reinstall AutoCAD with removing user preferences, but before you can try to Reset Application settings from Application tab of AutoCAD settings. And ... Could you make short screen cast of what happens and put it here before you try to reinstall?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 9
Bramborik
So by Resetting Application settings from Application tab of AutoCAD settings all is good. It worked. I forgot to do screenshot before I did the Reset but I did one after:) and noticed one thing, the hatch editor or viser on top of the screen is now nice in the middle but before it was on right side so I couldn't se the end of it (I never notice until now) so I was thinking maybe the whole window was somehow shifted...And when I click on hatch it tried to get closer to hatch editor....
”Boost
