Is it just me, or is the hatch visor missing basic functionality that was in the 2011 dialog box? For example, there is no checkbox for associative hatches. The online manual discusses a hatch dialog box that appears to be the old 2011 bhatch dialog box, but I can't find how to get it. I can't figure out any way to make a hatch pattern associative other than the HPASSOC system variable. The 2012 visor is very pretty, but it seems to be missing several options.
Solved by maxim_k. Go to Solution.
Hi John,
When you start HATCH command, at "Pick internal point or [Select objects/seTtings]:" prompt just type "T" to open old-style hatch dialog (or right-click and select "seTtings" from context menu).
If you want to edit hatch via dialog box - double click on it - you will go directly to Hatch Edit dialog.
HTH
Maxim
Aha-there it is. Like most things Autodesk, it is easy once you know how to do it. Thanks so much for your help. I will have to start watching the command line closer. They should put a settings button on the visor. Maybe a tiny little bitty arrow in a tiny little bitty grey circle. 🙂 Thanks again.
