Hi all,
I want to place an image (jpeg) onto my dwg so I can trace around it (then delete it), I cannot see any option of uploading ANYTHING on the tool panel
and have tried the command IMAGEATTACH and that didnt work!
I'm completely new to this MAC version therefore need an explanation in the simplest of terms 🙂 Please help!
Lindsey
Welcome to the Autodesk Forums!
Hi Lindsey,
IMAGEATTACH command works for me just fine:
Command: IMAGEATTACH
Specify insertion point <0,0>:
Base image size: Width: 1.000000, Height: 0.750000, Millimeters
Specify scale factor <1>:
How do you call this command?
Have you tried select from menu: Insert -> Raster Image Reference ?
Maxim
