I looked everywhere to learn how to do this simple task and cannot find any instruction.
The insert fields dialog box contains several fields that must allow the user to define the values for those fields but I cannot find where. For example, in the documents fields category there are fields named "comments" "keyword" "author" etc. Where do I enter the value for them so that when I insert the field I get more than just "---" returned?
Thank you kindly for your time!
These fields ("comments" "keyword" "author" etc.) populated only if you filed out Drawing properties with DWGPROPS command, which is available only in Windows version of AutoCAD.
Maxim
