I have AutocadLT for Mac. I select an item for copying or move and the regeneration of the selected item when dragging is now extremelly slow. It started happening after I downloaded the new Mavorick system. Is there a way to fix this?
Welcome to the Autodesk Forums!
Which version of AutoCAD LT do you have? 2013 or 2014?
If it is 2013, then it is not compatible with Mavericks. You do not have to update the OS until new SP will be ready.
If it is 2014, then check DRAGP1 system variable, by default it should be 5000, try to decrease number and look how it help you (with DRAGP1=0 you will not see anything when you copy-move objects).
Maxim
Hi Rick,
@skippy1956 wrote:
...The problem started after
I downloaded the new operating system.
You shouldn't have done it, AC 2013 for Mac still not compatible with Mavericks.
Now you can only try to install Beta 1 of Service Pack 2 for AC 2013 for Mac:
and see if it helps to resolve the issues.
Maxim
