Is is possible to disable the F1 key, or assign it to Esc instead of Help? I did that on Autocad for Windows as I frequently hit it by mistake.
thanks
Solved by maxim_k. Go to Solution.
OK,
I just checked, my solution will work in both AC 2013 and in AC 2014.
Unzip attached AcceleratorRoot.cui file and put it inside AuoCAD application to:
/Applications/Autodesk/AutoCAD 2013/AutoCAD 2013.app/Contents/Resources/ - for AC 2013
and to
/Applications/Autodesk/AutoCAD 2014/AutoCAD 2014.app/Contents/Resources/ - for AC 2014
YOU HAVE TO BACKUP ORIGINAL AcceleratorRoot.cui FILE BEFORE COPY
Now F1 will work as ^C^C
Maxim
