I've used the windows version for years, and just now am forced for the time being to work with AutoCAD mac, was that a tool pac option i had? i don't know, any help is appreciated.
I'm using AutoLISP routine (in attachment) for this.
The routine was written in 1992 by Gary Calwell and it is free.
DESCRIPTION:
CHSPACE allows entities that have been drawn in paper space to be moved to model space and visa versa. Tilemode must be set to 0 otherwise an error message is given and the program terminates. This program works by making a block of the desired entities and then inerting them, exploded into the desired space. Consequently it is easy to change the insertion point, and scale of the entities in the new space.
To run, type: CHSPACE tilemode must be set to 0.
Next select the entities you wish to change and a reference point (the default is 0,0,0). Then select the new reference point in the new space (the default is 0,0,0) and finally select the scale (default = 1). If there are no active viewports on screen, a message is given and the program terminates.
Maxim
