hi
i downloaded autocad 2014 free trail for the iMac and im having problems opening drawing which were created in autocad from older additions ie 2012
just wondering if any issue with the free trail or something else
regards
jer
are you sure that you run AutoCAD 2014 on Mac? I only know AutoCAD 2013 for Mac (OS) currently.
And what problems are these? Do you get any information, any exception, any error message?
Have you tried command _RECOVER to get those drawings opened-with-repair?
- alfred -
i can see the drawing in the perview but when i go to open the drawing it just does not open. there is nothinng in the command bar to say recover drawing, or give any error warning...
Start AutoCAD, then start command _RECOVER and select the drawing you can't open, does that work now?
Have you tried multiple drawings or just one?
- alfred -
