AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
DIAGONAL LINES APPEAR IN TRANSPARENT HATCHES
6 REPLIES 6
makstudio
17281 Views, 6 Replies
When I create transparent solid hatches, diagonal lines appear, following the shapes of triangles that AutoCAD uses to draw the solid hatches. These lines appear in both the preview and when plotting directly to our HP DesignJet 1055CM Plus plotter (ie skipping the pdf viewer). How do I get rid of these lines?
We are trying to overlay transparent hatches over other hatches to indicate shadows over tinted objects on an elevation.
6 REPLIES 6
maxim_k
in reply to: makstudio
Yes, you are right, there is such bug in AutoCAD for Mac (since 2011 release).
But I recently found workaround, for details look here in my blog:
Workaround For Printing Solid Hatches With Transparency In Autocad For Mac
HTH
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
makstudio
in reply to: maxim_k
Maxim, sorry for the late response. Yes, your work around did the trick and saved the day. We were able to create a great looking presentation and met our deadline thanks to you. If you're not on AutoDesk's payroll, you should be, or at least have some honorary title like "AutoCAD guru".
Milton
MAK Studio
maxim_k
Hi Milton,
I'm glad I could help you.
And I think *Expert Elite* = "AutoCAD guru" Smiley Happy
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
casparhustinx
Hi Maxin,
I am experiencing the same diagonal lines issue. I am using AutoCAD 2016. Despite going through your workaround suggestion, eg. setting the gradient hatch to fill with 2-identical colors, in conceptual visual style, these diagonal lines are still shown and printing in the 3d objects. The blue component of the pallet is on its own layer with a 70% transparency. The rest of the components are on another layer with its own 70% transparency (see screen dump). When printed, the result is identical. I have tried printing with "Nitro pro" as well as directly with the other options such as "Microsoft to pdf" or "dwg to pdf" print options (yes, with transparency ticked).MODEL Gradient 2 identical color plank.jpg
All the pallet-components in the enclosed example drawing are part of an Xref object (that should not be the cause of this issue). I am attaching a few screen dumps of the 3d object and the various settings. Perhaps you see something out of the ordinary?
Thank you in advance for looking into this matter.
maxim_k
in reply to: casparhustinx
Welcome to Autodesk Forums!
Hi Caspar,
Looks like you are using AutoCAD for Windows, but you posted your question in AutoCAD for Mac Forum.
Please ask your question here:
https://forums.autodesk.com/t5/autocad-forum/bd-p/706
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
casparhustinx
WOOPS!
Sorry about that! Thank you, Maxim, for pointing out the mistake.
CH
”Boost
