AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Changing solids generated by extrude command into 3D solid primitives.
3 REPLIES 3
kavgreenleas
353 Views, 3 Replies
I'm at the beginning of understanding 3D CAD and working through the Omura/Graham Autodesk book. I was puzzled by the different way grips and Gizmos were available to me on what I thought were similar solids. After searching the user guide, I find that solids created using primitives and those created using the Extrude command have different Grips and Gizmos. Can the Solids created by Extrude have their properties changed to make them a solid of primitive origin?
3 REPLIES 3
maxim_k
in reply to: kavgreenleas
Grips are different, but Gizmos are identical, because you use Gizmos for such transformations as Move, Rotate and Scale.
You can not convert extruded 3D Solid (box. for example) to Box object.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
kavgreenleas
in reply to: maxim_k
Thanks Maxim. Still getting to grips (sorry about that!) with Gizmos. Presumably one would try to generate 3D solids with primitives if you can. I guess extrude is mostly used with non simple polylines?
maxim_k
It is up to the Designer and design situation - some prefer extruded primitives because you can, for example control taper angle during or after creation.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
