I didn't manage to find a solution for my problem in the other threads.
I basically want to change the hotkeys for the ortho and the osnap to something different from a function key.
I know that by default they can be toggled by pressing fn+F8 and fn+F3; I also know I can turn on "Use F1, F2 ... as Function keys" in Keyboard pane of System Preferences. However I want to set two "letters" (such as q and w) as shortcuts for these two functions because I want to press only 1 key both while using autocad and while using the volume/brightness commands of my macbook.
Thank you.
The topic title has been edited to improve findability by @alina.balkanskaia. Original: Changing hotkeys for ortho and osnap
Solved by maxim_k. Go to Solution.
Just to add that shortcut key customization is available in AutoCAD Mac 2022 version.
https://help.autodesk.com/view/ACDMAC/2022/ENU/?guid=GUID-A62BFCCC-9E89-404E-BF28-A12668D738D2
