I have a Block, with Attributes, 100 times in my Drawing.
When I change the Textheight with Blockeditor, all of them should change.. I expected that, but it doesn't work...
How do I change the Textheight without opening each single one?
Thnx!
Welcome to Autodesk Forums!
You have to use Block Attribute Manager to edit text properties of block attributes and apply them to all inserted blocks.
Start BATTMAN command (menu Modify->Block->Block Attribute Manager)
Select block you want to change from drop-down list at the top, double-clock on Options field
In Attribute Editor change text properties you need:
Click OK, this will return you to previous dialog. Click on Synchronize blocks button:
Close dialog. All insertions will be updated.
Maxim
