I recently downloaded the trail lt version 2013 for mac. Ive been running LT 2012 on a windows and has worked great but when its comes to x references on the mac im having some issues. everytime i go into my xref command to load some dwgs some of them are coming up with the name IDS_XATTACH_CPP_2 and i dont have any files named that and for example ill select building type 2 parcell f which is the name is the doccument. once i click ok and go to drop it on my model space it changes name and its a totaly different dwg. Its not just the one dwg its multiple references.
If anyone knows why this may be happeneing please help out
thanks!
i posted 2 pictures of the file being selected and then what it changes to
Solved by maxim_k. Go to Solution.
well that worked! renamed them to 1.dwg etc. thank you maxim. Im not sure why now acad is not recognizing my orignal file names but thank you for all you help.
@lvpcad wrote:yea sure my original file name was Parcel A bldg type 1 level 1,2
Comma not allowed in named object names (Xref in your case), so AutoCAD generates new name for Xref.
Another thing is that when you insert next external reference with a different name (that also doesn't allowed) AutoCAD doesn't generate new name for new Xref, assign the same name and as a result inserts the new instance of the first Xref. This looks like a bug.
Maxim
