Was wondering if someone might be able to find out what might be causing the issues for me.
As corporate standard we always print to PDF. I have a dwg file that has 4 layouts, 3 of which are 11x17 and one that is 24x36. When I batch plot, the 24x36 layout is plotted to a PDF of 11x17 size (truncates total drawing). But when I individial plot print the 24x36 to PDF it turns out fine.
Any ideas or suggestions?
PS. There's an option in batch plotting that says "Page setup detail : Override output device specified in current page setup and publi..." , I'm wondering if this might have something to do with it, and how can I modify it so that it won't override the output device, and plot using the page setup details for that layout instead.
Thanks.
Solved by maxim_k. Go to Solution.
Hi
I am experiencing the same problem with the top and right edges trimmed/ truncated as seen in the attachment.
I tried using single sheet. Can somebody tell me what could be the problem?
