I feel like I typed in something wrong while showing something to my boss today and I cannot for the life of me figure out what I did to cause this issue. It's nothing more than extremely annoying and I just want to know what command/tool I need to toggle it off. It was easiest to just show a photo (attached) of what is going on.
Basically, I am getting an automatic extension line inserted along the x-axis only for 2D drawings. When I am constructing 3D models I have no such annoyances. I'm positive it's something I did and just want to know how to correct this issue. It has been a few years since I have used AutoCAD so I am 'crash coursing' back into this and still haven't remembered or figured everything else out.
The image that is attached is just an example of what's going on and I just want to toggle this feature off.
Any help would be awesome. Thank you!
Thanks for the welcome and the quick response.
I am running on a Mid-2011 iMac 3.4 i7 with 16GB RAM. I did not have any issues at the installation or the first few models I was working on. Now that you mention it this happened after I made a much more detailed model, but this is happening even when I start a new drawing like the image I originally attached. In that drawing I was just in a parallel perspective 2D wireframe view and those "extensions" will show up unless it is a 3D model. Regardless of the Visual Style if the object is a 3D model they do not show up. They do show up for every line drawn and in all of the 2D plan drawings. When I then shift over to layout though, they are gone. You can catch them flicker when zooming in or out during the layout process, but they do not show up like they do within the model drawing.
Everything that I keep seeing, finding, or not finding is leading me towards a hardware issue which is good to know since I am just using the trial version of AutoCAD to make sure that my hardware can handle it before my workplace purchases the premium license.
Again, thanks for the help so far.
I have the same issue a lot and have found that if you exit autocad and re-launch that will clear up the extended line issues. Maxim is correct in that your ucs appears to be set to something other than 2d wireframe. Could be you are using a 3d templete file?
Maxim
System Bio Is:
Mac OS X Version 10.7.5
Processor 3.4 GHz Intel Core i7
Memory 16GB 1333 MHz DDR3
Graphics AMD Radeon HD 6970M 2048MB
Sorry for the delayed response. Way too much work happening right now.
My system is on Mac OS X 10.8.5. When I exit AutoCAD and restart it the issues clear up, also you're right I wasn't in the 2D wireframe view. I am wondering if these issues are a result of the AMD Radeon 6970M graphics card. According to CNET at the end of August Apple started a program to replace faulty graphics cards in mid-2011 to late-2012 iMacs with the 6970M graphics cards.
This is very interesting - I will get in touch with Apple to discuss as I have a system that falls under the replacement program. Thanks for the info!
