Hi!
Hope somebody can helpme with this. I just go updated to Mavericks and Autocad 2014, but I have a problem, I can't plot any layouts!
When I hit plot the print window opens, then i can choose printer and plot styles very well. But, when I choose print just doesn't work 😞 The window dissappear and nothing happens.
It's the same if I choose Open PDF in preview or save to PDF, just doesn't work.
Please help!
Many thank's!
Solved by shabaza. Go to Solution.
hei Egidio, i also got problem as ur, but i have solve it and i realize that mac plotter is also easy,.
this is u have to do go o > edit page set up > paper size > manage custom sizes > + > select from list
now u can view preview pdf and save it, hope it will help u, thx
Recently I got OSX Yosemite and had to install again Autocad. The problem is when I use plot and save as pdf option , later I can not open that pdf in Photoshop, just a blank page, but I can open it in preview or quick view. Also, How can I change paper size units from in to mm? The same problems occurs on autocad 2015 and 2014. Before, I havent had these kind of problems. Also when I plot same dwg on windows and autocad 2015, pdf is normal and Photohop opens it.
Thank u in advance! I hope someone can help,its urgent.
Andrea
