AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Autocad 2014 Mac plot layout problems
62 REPLIES 62
Message 1 of 63
13949 Views, 62 Replies
Hi!
Hope somebody can helpme with this. I just go updated to Mavericks and Autocad 2014, but I have a problem, I can't plot any layouts!
When I hit plot the print window opens, then i can choose printer and plot styles very well. But, when I choose print just doesn't work 😞 The window dissappear and nothing happens.
It's the same if I choose Open PDF in preview or save to PDF, just doesn't work.
Please help!
Many thank's!
62 REPLIES 62
Message 2 of 63
maxim_k
Welcome to Autodesk Forums!
What printer model do you have on your Mac? - Please look which printer model is active when you try to print or save to PDF?
I also want ask you to post here screenshot of Application tab of AutoCAD Preferences dialog with information about printing expanded, especially "Printer Support File Path" and "Print Spooler File Location".
It would be helpful to have Console output messages at the moment when you try to print (system.log)
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 63
bastia
Same problem!!!
It work only if sheet size is specified in print layout window. The sheet size value previously specified in page setup window is not recognize in print layout menu. So i have to set sheet size every time.
Printing in autocad for mac is very exhausting
Message 4 of 63
maxim_k
Could you answer the questions in my previous post about System printer?
Do you confirm you are using AC 2014 on Mavericks?
Do you create new Page Setup for Layout and give it a name in Page Setup dialog? Or you just edit the default page setup?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 63
bastia
in reply to: maxim_k
i confirm autocad 2014 (trial version) and mavericks
the steps are the follows:
- i create a new layout
- then i select Edit Page Setup to set printer, page format etc..
- then i select Print Layout
- the paper size is set to custom (the previously setting of page size are missing)
and
- if i select preview or print button it doesn?t work
- if i set the missed paper size it start print or preview
thanks
egidio
Message 6 of 63
maxim_k
in reply to: bastia
Hi Egidio,
Once again: do you have printer installed on your Mac? (System Preferences -> Print&Scan pane)
Which page format do you select when you edit page setup? If you select predefined page format (A4, Letter, B5, etc.) which page size you see when you select "Print layout"? What do you mean by "custom"?
Could you provide screenshots of Page Setup and Print dialogs?
Did you give your page setup some name (e.g. do you create new page setup in Page setup dialog with "+" button, or just edit the existing one)?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 63
bastia
hi Maxim
of course i have installed printers on my mac (Hp plotter device and Canon Laser device) and
attached two screenshot to explain:
in the first one i set page setup settings (i didn't find any way to save these setting with a name)
in the second one previous setting are missing
I tried to save print settings by Page Setup Manager by clicking on (+) and give a new name, but i didn't find a way to recall it in my "Page Setup" or "Print Layout"
thank you
egidio
Message 8 of 63
maxim_k
in reply to: bastia
Do you see on the second screenshot Page setup: <None>, I think that the problem is here.
It appears that you are printing from Model space (or I'm not right?)
After you created Page setup in Page Setup manager, you gave it the name "A2_rot_61cm" as I see, you need to set it current in first dialog of Page Setup manager, where you can see the list of all Page Setups. Use "gear" button to set "A2_rot_61cm" current, then you should be able to see all your settings when you call Print dialog.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 63
bastia
maybe this screenshot can help to find a solution.
Error report, casually opened after batch printing, indicate tha PMP folder not Found.
thanks
Egidio
Message 10 of 63
maxim_k
How do you create Custom Paper size? Could you provide step-by-step workflow?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 63
bastia
Hi, OK
the following are the steps of workflow
- I create a new Layout
- I am now in "Paper Space"
- Click on "Edit Page Setup"
- i choose printer/plotter
- on paper size i select "manage custom size" to custom my page size and give it a name
-i set others parameters and click OK
- i am always in "Paper Space"
- then i click on Print Layout and here i didn't find previous settings
- OK! now  i click in Edit Page Setup (i am always in the "Print Layout" window)
- Edit Page Setup menu Appear and this time with a new option (see below)
-now i can set again but anyway it seem there is something that doesn't work fine in autocad for mac..
thanks
Egidio
Message 12 of 63
maxim_k
Could you try another workflow:
While in Layout, start Page Setup Manager (File->Page Setup Manager).
Create new Page setup (with "+" button), give it a name, then edit as you did previously). When you wil return to Page Setup manager- select Page setup you just created an set it current ("gear" button).
Now try to call Print command. Does your settings appear in Print dialog?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 13 of 63
bastia
i tried your workflow but it doesn?t work
i thank you very very much
Message 14 of 63
maxim_k
in reply to: bastia
I tried yours from message #7 ( http://forums.autodesk.com/t5/AutoCAD-for-Mac/Autocad-2014-Mac-plot-layout-problems/m-p/4673193#M102... ) and it works differently in my case. After I edit Page setup of the Layout via button on Paper space Visor and I open Print dialog - all settings, including paper size and the name of custom paper size are here.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 15 of 63
maxim_k
in reply to: bastia
Hi Egidio,
After analyzing all thread again I came to the conclusion that the case of the issues you have (PMP error report, inconsistencies in the Page Setup settings you create and the information in Print dialog) is in Custom paper sizes you have on your Mac. For some reason AutoCAD can not read them correctly, thus it can not find correct paper size when printing (PMP error) or when it opens Print dialog.
Maybe I'm wrong, but in your place I'd check this.
You can try to delete all Custom paper sizes you have on your Mac and create them again.
Hope you can resolve issues with printing.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 16 of 63
bastia
HI,
I tried to delete custom size i tried also to reinstall software with all custom preferences, ?. no way!!
Same errors also in batch publish.
I don?t know what to do!!
thanks again
egidio
Message 17 of 63
maxim_k
I saw you open DWG file from Network location or from external media. Do you have the same issues if you open file from some location inside your Home folder?
Before batch printing- do you see any alerts in the list of files you want to print?
What if you try to rename DWG file you want to print to something simple, such as Test.dwg (with only Latin symbols)?
I also have another idea, but could you test the above at first?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 18 of 63
bastia
Hi, i have tried but no way! In batch print no alerts!!
I think that my autocad does not recognize custom page size. It seem to work fine with standard page size selected from the list.
Egidio
Inviato da iPhone
Message 19 of 63
maxim_k
in reply to: bastia
Could you test if some other application can recognize custom paper sizes, for example Preview.app
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 20 of 63
sofipena85
Hi, i have a problem with the Plot Style Table.
I have several Plot Styles (CTB) in my computer, buy Autocad 2014 doesn't recognize them.
As you can see in the pictures, the Plot Style Table has 5 opciones (STB),  but i want to use the CTB i already pre configued.
How can i do to fix this??
Tks
Tags (1)
”Boost
