AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Autocad 2013 mac doesn't start!!!
9 REPLIES 9
Message 1 of 10
michele1.fanelli
1346 Views, 9 Replies
I'm trying to install autocad 2013 on my mac...
I downloaded the student version and I installed it but when i try to start it, it exit without any error message!!! Do u have any suggestion? I have a Mac OS 10.6.8.... I hope to find a solution asap!
( I have already set my mac in English language!)
9 REPLIES 9
Message 2 of 10
maxim_k
in reply to: michele1.fanelli
Hi Michele,
Do you have Adobe software (Illustrator, Photoshop) on your Mac?
BTW, there is no need to set default System language to English for AC 2013.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 10
michele1.fanelli
in reply to: maxim_k
Ok because on facebook, autodesk said me to set the language in english!
However i only have Adobe Acrobat Professional!
Is this the problem? how can I fix it?
Ps thank u for your reply!
Message 4 of 10
maxim_k
Then you can try the solution from my blog:
macacad.wordpress.com/2010/11/25/autocad-for-mac-and-adobe-software/
It is about AC 2011, but also applies to 2013.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 10
michele1.fanelli
I find no ‘FLEXnet Publisher’ folder in ‘/Library/Preferences/’.
What can I do?
Message 6 of 10
maxim_k
Are you looking in Library folder in the root of Mac HD (not inside your home folder)?
Could you post an exception from Console log during AutoCAD launch?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 10
thank u so much!!!!! I made a mistake because of the wrong directory!
Now everything is ok.... thank u so much for your help and patience!
Message 8 of 10
RayGrimaldi
hi maxim,
i have the same problem with her but i couldn't find FlexNet in my Preferences.
Here's my console log:
Apr  1 16:24:11 ray-grimaldi-erwins-macbook-pro [0x0-0x3b03b].com.autodesk.AutoCAD[954]: Autoload Feature Installed
Apr  1 16:24:11 ray-grimaldi-erwins-macbook-pro [0x0-0x3b03b].com.autodesk.AutoCAD[954]: Materials Configuration Not Found in the Bundle - Skipping
Apr  1 16:24:14 ray-grimaldi-erwins-macbook-pro LMU[998]: 998 DAEMONIZE: setting umask 0
Apr  1 16:24:14 ray-grimaldi-erwins-macbook-pro LMU[998]: 998 DAEMONIZE: session parent exiting
Apr  1 16:24:14 ray-grimaldi-erwins-macbook-pro LMU[998]: exiting and supressing hooks: 0
Apr  1 16:24:14 ray-grimaldi-erwins-macbook-pro LMU[999]: 999 DAEMONIZE: session new session leader
Apr  1 16:24:14 ray-grimaldi-erwins-macbook-pro LMU[999]: 999 DAEMONIZE: tty disconnect parent exiting
Apr  1 16:24:14 ray-grimaldi-erwins-macbook-pro LMU[1000]: 1000 DAEMONIZE: tty disconnect child
Apr  1 16:24:14 ray-grimaldi-erwins-macbook-pro LMU[1000]: 1000 DAEMONIZE: closing file descriptors
Apr  1 16:24:14 ray-grimaldi-erwins-macbook-pro LMU[1000]: 1000 Execing /Applications/Autodesk/Adlm/R4/LMU.app/Contents/MacOS/lmuopen
Apr  1 16:24:14 ray-grimaldi-erwins-macbook-pro LMU[1000]: 1000 with argument: lmuopen
Apr  1 16:24:14 ray-grimaldi-erwins-macbook-pro LMU[1000]: 1000 with argument: /Applications/Autodesk/Adlm/R4/LMU.app/Contents/MacOS/LMU
Apr  1 16:24:14 ray-grimaldi-erwins-macbook-pro lmuopen[1000]: Launching: /Applications/Autodesk/Adlm/R4/LMU.app/Contents/MacOS/LMU
Apr  1 16:24:14 ray-grimaldi-erwins-macbook-pro system_profiler[1003]: could not convert interface name
Apr  1 16:24:14: --- last message repeated 2 times ---
Apr  1 16:24:14 ray-grimaldi-erwins-macbook-pro auditd[1005]: Auditing enabled
Apr  1 16:24:14 ray-grimaldi-erwins-macbook-pro auditd[1005]: Got low space trigger
Apr  1 16:24:14 ray-grimaldi-erwins-macbook-pro auditd[1005]: auditd_read_dirs(): all audit log directories over soft limit
Apr  1 16:24:14 ray-grimaldi-erwins-macbook-pro auditd[1005]: renamed /var/audit/20130401090825.not_terminated to /var/audit/20130401090825.20130401092414
Apr  1 16:24:14 ray-grimaldi-erwins-macbook-pro auditd[1005]: New audit file is /var/audit/20130401092414.not_terminated
Apr  1 16:24:14 ray-grimaldi-erwins-macbook-pro _spotlight[1009]: audit warning: allsoft
Apr  1 16:24:14 ray-grimaldi-erwins-macbook-pro _spotlight[1011]: audit warning: closefile /var/audit/20130401090825.20130401092414
Apr  1 16:24:14 ray-grimaldi-erwins-macbook-pro _spotlight[1010]: audit warning: soft /var/audit
Apr  1 16:24:24 ray-grimaldi-erwins-macbook-pro com.apple.launchd.peruser.501[204] ([0x0-0x3b03b].com.autodesk.AutoCAD[954]): Exited with exit code: 255
Apr  1 16:25:04 ray-grimaldi-erwins-macbook-pro LMU[999]: exiting and supressing hooks: 0
thanks
Message 9 of 10
maxim_k
Have you checked free space on your HD? Looks like you are close to running low disk space. Not sure, but maybe it is the reason.
About FLEXnet folder- it should be inside Library/Preferences folder in the root of your HD if you have Adobe software or if you already work in AutoCAD on your Mac.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 10
prolloz
I have the problem with my computer. I have tried removing the files you said, (flex... whatever) removing other elements you said in other questions and the list time I installed Autocad I did it as a trial, then it opened and said that it needed to be verified I entered my serial number and after that it said that it was ok but then it shut down. when I try to restart Autocad it brings up the start image but then it closes without saying a thing.
At the console this is what it appears:
4/12/13 8:12:11.677 PM [0x0-0x12e12e].com.autodesk.AutoCAD: set SkipExisting to true
4/12/13 8:12:11.689 PM [0x0-0x12e12e].com.autodesk.AutoCAD: Materials Configuration Not Found in the Bundle - Skipping
4/12/13 8:12:17.549 PM [0x0-0x12e12e].com.autodesk.AutoCAD: AcadDMSEHHELPER attach
And then it closes.
”Boost
