I'm trying to install autocad 2013 on my mac...
I downloaded the student version and I installed it but when i try to start it, it exit without any error message!!! Do u have any suggestion? I have a Mac OS 10.6.8.... I hope to find a solution asap!
( I have already set my mac in English language!)
Ok because on facebook, autodesk said me to set the language in english!
However i only have Adobe Acrobat Professional!
Is this the problem? how can I fix it?
Ps thank u for your reply!
thank u so much!!!!! I made a mistake because of the wrong directory!
Now everything is ok.... thank u so much for your help and patience!
hi maxim,
i have the same problem with her but i couldn't find FlexNet in my Preferences.
Here's my console log:
Apr 1 16:24:11 ray-grimaldi-erwins-macbook-pro [0x0-0x3b03b].com.autodesk.AutoCAD[954]: Autoload Feature Installed
Apr 1 16:24:11 ray-grimaldi-erwins-macbook-pro [0x0-0x3b03b].com.autodesk.AutoCAD[954]: Materials Configuration Not Found in the Bundle - Skipping
Apr 1 16:24:14 ray-grimaldi-erwins-macbook-pro LMU[998]: 998 DAEMONIZE: setting umask 0
Apr 1 16:24:14 ray-grimaldi-erwins-macbook-pro LMU[998]: 998 DAEMONIZE: session parent exiting
Apr 1 16:24:14 ray-grimaldi-erwins-macbook-pro LMU[998]: exiting and supressing hooks: 0
Apr 1 16:24:14 ray-grimaldi-erwins-macbook-pro LMU[999]: 999 DAEMONIZE: session new session leader
Apr 1 16:24:14 ray-grimaldi-erwins-macbook-pro LMU[999]: 999 DAEMONIZE: tty disconnect parent exiting
Apr 1 16:24:14 ray-grimaldi-erwins-macbook-pro LMU[1000]: 1000 DAEMONIZE: tty disconnect child
Apr 1 16:24:14 ray-grimaldi-erwins-macbook-pro LMU[1000]: 1000 DAEMONIZE: closing file descriptors
Apr 1 16:24:14 ray-grimaldi-erwins-macbook-pro LMU[1000]: 1000 Execing /Applications/Autodesk/Adlm/R4/LMU.app/Contents/MacOS/lmuopen
Apr 1 16:24:14 ray-grimaldi-erwins-macbook-pro LMU[1000]: 1000 with argument: lmuopen
Apr 1 16:24:14 ray-grimaldi-erwins-macbook-pro LMU[1000]: 1000 with argument: /Applications/Autodesk/Adlm/R4/LMU.app/Contents/MacOS/LMU
Apr 1 16:24:14 ray-grimaldi-erwins-macbook-pro lmuopen[1000]: Launching: /Applications/Autodesk/Adlm/R4/LMU.app/Contents/MacOS/LMU
Apr 1 16:24:14 ray-grimaldi-erwins-macbook-pro system_profiler[1003]: could not convert interface name
Apr 1 16:24:14: --- last message repeated 2 times ---
Apr 1 16:24:14 ray-grimaldi-erwins-macbook-pro auditd[1005]: Auditing enabled
Apr 1 16:24:14 ray-grimaldi-erwins-macbook-pro auditd[1005]: Got low space trigger
Apr 1 16:24:14 ray-grimaldi-erwins-macbook-pro auditd[1005]: auditd_read_dirs(): all audit log directories over soft limit
Apr 1 16:24:14 ray-grimaldi-erwins-macbook-pro auditd[1005]: renamed /var/audit/20130401090825.not_terminated to /var/audit/20130401090825.20130401092414
Apr 1 16:24:14 ray-grimaldi-erwins-macbook-pro auditd[1005]: New audit file is /var/audit/20130401092414.not_terminated
Apr 1 16:24:14 ray-grimaldi-erwins-macbook-pro _spotlight[1009]: audit warning: allsoft
Apr 1 16:24:14 ray-grimaldi-erwins-macbook-pro _spotlight[1011]: audit warning: closefile /var/audit/20130401090825.20130401092414
Apr 1 16:24:14 ray-grimaldi-erwins-macbook-pro _spotlight[1010]: audit warning: soft /var/audit
Apr 1 16:24:24 ray-grimaldi-erwins-macbook-pro com.apple.launchd.peruser.501[204] ([0x0-0x3b03b].com.autodesk.AutoCAD[954]): Exited with exit code: 255
Apr 1 16:25:04 ray-grimaldi-erwins-macbook-pro LMU[999]: exiting and supressing hooks: 0
thanks
I have the problem with my computer. I have tried removing the files you said, (flex... whatever) removing other elements you said in other questions and the list time I installed Autocad I did it as a trial, then it opened and said that it needed to be verified I entered my serial number and after that it said that it was ok but then it shut down. when I try to restart Autocad it brings up the start image but then it closes without saying a thing.
At the console this is what it appears:
4/12/13 8:12:11.677 PM [0x0-0x12e12e].com.autodesk.AutoCAD: set SkipExisting to true
4/12/13 8:12:11.689 PM [0x0-0x12e12e].com.autodesk.AutoCAD: Materials Configuration Not Found in the Bundle - Skipping
4/12/13 8:12:17.549 PM [0x0-0x12e12e].com.autodesk.AutoCAD: AcadDMSEHHELPER attach
And then it closes.
