Can Autocad 2013 for Mac works with MAc OSX mavericks?
Hi ALPER,
It should work, because it is the same as officially released SP2:
AutoCAD 2013 for Mac (full and LT) SP2 is available for download
Could you provide more details?
You can not launch AutoCAD? Or you have some troubles when you work with it?
Maxim
Hi there,
I have also downloaded the advised SP2 for LT (2013), because of mavericks, but when I start up it launches, opens my drawing or new page, however instanly freezes and I get the spinning wheel. I have waited for a few minutes to no avail. Please advise and thanks in advance.
I have just updated to Mavericks. I had no idea that there were issues with Autocad - Bad move. All seems to be working well until I need to plot. As soon I try to Edit page setip i get a blank pop up. I tried to install the service packs but am getting this response to the type _vernum command: "G.55.M.2" (read only)
What does this mean? I desperately need to get this sorted for work.
Please help!
Thank you
I just upgraded to mavericks and I was running autocad lt 2013 on OSX 10.7 before. I updated through the app store but I am not sure if I have managed to install 2013.2. The version number says: "G.55.M.208" (read only). Can someone let me know if this is the most current version of autocad lt 2013.2 which will run on mavericks? Thank you for your help...
I am still getting G.55.M.2 - read only. Can someone please tell me what I am doing wrong? I have installed both service pack 1 and 2 based on your instructions - Acad mac 2013 with Mavericks 😞
Thats it. I cant understand what Im doing wrong. I have uninstaled and reinstalled Acad removing prefernces.
Acad does run without the service packs. My main issue - so far is plotting - I cannot edit page setup - when i select that option I get a black dialog box. I cant set my print settings etc without accessing that. I also would like to set it to centre on page. Otherwise.. So far I can do everything else, but theres no point in working if I cant print or set pdf Exports properly.
Has anyopne else had this problem? Im clearly missing a step as everyone else seems to have no problems installing the service pack.
Ive just realised your links are for Acad 2013... not Acad lt 2013.. I am downloading the service pack 1 for Acad lt 2013 - mac. There doesnt seem to be a service pack 2. Is this all I need?
