Does anyone know how to change the default "Save" setting so that the files are saved to an earlier version of AutoCad?
If you have non-AppStore version of AC LT 2013 for Mac, try this:
http://macacad.wordpress.com/2012/09/03/setting-default-format-for-save-in-autocad-lt-for-mac/
For Mac AppStore version of AC LT 2013, try this:
Maxim
copy everything below in RED into your command line and hit ENTER
(setenv "DefaultFormatForSave" "36")
note:
*After you run the command, you can test by clicking SAVE AS to see if the default save version is changed.
*you can replace the number 36 into below for a specific version you wanna save into.
1 - AutoCAD R12 DXF
12 - AutoCAD 2000 DWG
13 - AutoCAD 2000 DXF
24 - AutoCAD 2004 DWG
25 - AutoCAD 2004 DXF
36 - AutoCAD 2007 DWG
37 - AutoCAD 2007 DXF
