AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
AutoCAD won't group.
7 REPLIES 7
Message 1 of 8
rgwhatley
20481 Views, 7 Replies
AutoCAD has stopped 'grouping' objects. If I select mulitiple objects to group then cmd + g (or group in tools) it doesn't allow me to select the group just invidual lines as if it is un grouped. However if I try to group again then it says the objects are already a member of a group. What have I done?
7 REPLIES 7
Message 2 of 8
pendean
in reply to: rgwhatley
What is PICKSTYLE variable set to? 1 or 3 is what you want.
Message 3 of 8
rgwhatley
Thankyou! it was set to 0. How did I turn that off?
Message 4 of 8
pendean
Probably a keyboard combination, it happens.
Message 5 of 8
ginnyeeee
You can click the AutoCAD Icon left side up,
there is "option"
and in the "Selection" tap,
at the "Selection Mode",
turn on the "object grouping"
Message 6 of 8
Emmsleys
Did any of the posts in the thread help with the issue?
Please use the
Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
Message 7 of 8
san_Repere
in reply to: Emmsleys
PICKSTYLE worked perfectely changing value from 0 to 1...
Message 8 of 8
san_Repere
Thank you so much
”Boost
