I have a new imac and 2014 LT AutoCAD software. When printing to my Canon iPF510 printer most of the lineweights between 0.1 and 0.25mm appear the same size (about 0.25mm or more). When I printed the same drawing from my old PC the lineweights were the correct size. Does anyone know if this is an AutoCAD setting or something to do with the printer. I have download the latest printer drivers, and printing from other applications appear fine.
Welcome to the Autodesk Forums!
Could you post here PDF file created on your Mac from AutoCAD with just two lines - one 0.25 mm and another 0.1 mm, and DWG file itself from which you create this PDF?
Maxim
Hi Andrew,
I checked your PDF in AI and everything is OK with lineweights:
So if you see the problem on the real paper, than maybe the case is in Canon printer driver.
Maxim
