I was really excited about AutoCAD for Mac. I have been an AutoCAD user for many years on the PC and am a big fan of the program. I have to say that I am disappointed in the output options available for the mac version. There is no plot to pdf option (the workaround for this is unacceptable). There is no plot style manager. There is no way to edit ctb files.
I'm not sure what to think about this. I am starting this thread with the hope that someone from Autodesk will please respond to address the lack of output functionality. Is Autodesk working on solutions to these problems? Is there a new way of managing output in the works? Should I continue using this program in the hope that there will be a solution or is this all there is going to be? Please respond Autodesk... If these problems don't get resolved then I'm afraid this program is of little use to me and though it's an old friend, at this point, I might have to move on.
If you are reading this and agree that these problems need resolution, please respond to this post so that the folks at Autodesk take notice.
I am having trouble of reducing the pdf sizes.
I am using autocad lt 2013 for mac.
I can't change DPI output settings for pdf.
even I don't know what DPI it is exporting.
Is there a way to change it?
Hey all
I'm having an issue with lineweights and stb's in AutoCAD 2016 for Mac. Exporting .pdf's works rather well all in all (some nearly unnoticeable artifacts around detailed objects), though I run into issues with the really thin lines ... When opening the exported .pdf's I notice that none of the lineweights in the PDF actually exactly matches the ones assigned through the plotstyle sheet. The difference is not really noticeable for the thicker lineweights, but there seems to be a minimum value at .042 mm (I can't go below it, even when I set the plotstyle lineweight to .001) . Anyone any idea what might be the issue here? The thinnest lines are supposed to be .02 mm thick in the PDF's (which are assigned through the plotstyle).
Attached are the plotstyle sheet, the CAD file and an example .pdf. The plotstyle in question is Make-Up_2, which in the pdf are the thin slightly grey rectangular hatches.
Kind Regards
Jonas
Thanks Maxim!
It took me a while to find the time to set up 2017 and try it out! So that's why it took me so long to answer. (:
But yes! 2017 with the publish command did it (: Thanks again for the quick reply
Kind Regards
Jonas
