AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
AutoCAD for Mac Startup Error: Unhandled Exception
6 REPLIES 6
3558 Views, 6 Replies
I have a 21.5", 2011 iMac running on Mac OS X Lion 10.7.3. I have the AMD Radeon HD 6750M graphics card and a 2.5 GHz Intel Core i5 processor.
I downloaded AutoCAD for Students, and it worked well for several days, but then began to crash whenever I would change layers.  After successfully restarting AutoCAD after those crashes, it now crashes before fully opening and has not been able to open for several weeks.
I get the error message: Unhandled Exception (Version E.49.H.554(x64)).  I have looked through other threads for a solution; this version of AutoCAD apparently doesn't support the AutoCAD 2011 for Mac updates though?
Help? Smiley Sad
6 REPLIES 6
maxim_k
You have to install all 3 Updates for AC 2011 for Mac in order to be able to run it on Lion.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: maxim_k
I have tried to install all three updates, but have never succeeded.  Each time I try, I get the message "You do not have a copy of AutoCAD installed which can be updated."
maxim_k
Can you try to create new account with admin privileges on you Mac and install Update from this new account?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
I tried this... It doesn't work 😞
I had the same problem with my autocad but it started to crash when I inserted a pdf image. Now I can't even open my software, it crashes at launch.
Were you able to find a solution ?
maxim_k
Welcome to Autodesk Forums!
Which AutoCAD version do you have?
If it is 2014 with SP1 installed, or 2015 - you can try to reset AutoCAD:
Hold Shift key on keyboard for a few seconds while you click on AutoCAD icon in the Dock:
https://macacad.wordpress.com/2014/03/16/new-way-to-reset-autocad-for-mac-settings-2014-version-with...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
