Dear All-
After spending hours and hours in the Apple store with the technicians, spending hours and hours in clean installing and reinstalling, I'm quite sure, that the installed Autocad LT 2014 for Mac causes the graphic problems with my MacBookPro Retina and Mavericks 10.9.1.
It's flikcering and jiggling. Not only within the Autocad application. The complete Mac system is affected.
When I scroll with Safari, Mail, Finder or whatever, flickering. When I move Finder windows on the screen, flickering.
Sometimes, when I move an attachment from the Finder directly into Mail the file is permanetly connected to the hand of the mouse and the Finder is no more working. All other applications still work, but the Finder is crashed. Then I have to shut down and restart the system. This I guess is one of the plenty Mavericks bugs, but maybe might be also affected by Autocad.
Any help?
Does the "Adaptive Degradation" in the preferences causes any effect? I couldn't see any dfifference.
By the way, when I disable "Adaptive Degradation" and close Autocad, it's again enabled when I restard Autocad.
Thank you
Andreas
The same problem to me! On MacBook Pro Retina AutoCAD 2014 for Mac causes graphic glitches! Only clean reinstallation helps! The problem is with the internal Intel graphic card! If the external graphic card is activated there is no problem with graphic. But by default AutoCAD 2014 do not switches to external graphic card so it causes great glitches!
Welcome to the Autodesk Forums!
What if you turn off "Automatic graphics switching" in Energy Saver pane of Mac OS System preferences. Than your Mac always will use "external" (dedicated) graphics card.
Maxim
I have exactly the same problem with my rMBP 15" Late 2013. I have partially solved it after a new motherboard got installed, so the issue appear now in the way asp65 related. Very annoyed with the experience, after 2 months dealing with system failures, finder crash, unable to surf the web, exposé not working. Now I am back with AutoCad 2014 running in Windows through Parallels but after 4 years using Mac this is NOT what i want. I have tried with my old MBAir mid 2011 and with only 2 GB (the rMBPro has 16 GB) can managed properly the latest version.
I have had this same issue in my retina. I actually went many times to the apple store to fix this issue thinking it was a hardware problem. I am quite relieved to know that this may be caused by my old friend autocad all along.
Do you know if autocad 2013 caused the same problem? Is there any save way to use Autocad on mac?
Watching the differences between the Mac 2014 version vs AutoCad 2015 i have switched to parallels with Windows 8.1. http://www.autodesk.es/products/autodesk-autocad/compare/compare-platforms
The recents updates, both in OS X and AutoCad 2014 for Mac haven´t resolve the issue ( I am actually using OS X Yosemite Beta 1) without any variation.
Did the problem persisted even with a clean install of Yosemite or did you updated the OS? I am not sure if being an issue of autocad yosemita can do much about it but it would be awesome if it did.
Do you get good performance with parallels? I tried it couple of years ago and didn't quite like it
Thanks!
Hey.
I have the same problem... The 2014 lt version is going to kill my mac.
I own a 2009 mac pro with an ATI radeon 7950 and osx 10.9.3.
When i lauch acad, a large part of apps seems to get down (reader, mail, safari, and maybe others).
For example, it is impossible to drop a file in a sending mail window, or sometimes just droping a file from a folder to another is too painfully. The mouse pointer disapears and takes the aparence of the file i want to displace.
I was planning to buy this software but gosh, i really don't know what i have to do; your team have to isolate the problem quickly.
Unfortunatly, i don't have crash report to send, but i am happy to see that i am not the only one to suffer with this.
