AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
AutoCAD 2014 for Mac missing dimensions toolbar
5 REPLIES 5
jchumphries
9878 Views, 5 Replies
I'm using AutoCAD 2014 for Mac - Student Addition. I'm trying to find my dimensions toolbar. I can't find it, much less any of my other toolbars aside from what's already there. How do I customize my toolbar selection?
Tags (1)
5 REPLIES 5
i have same problem, since installing it, i only have the properties toolbar and layers open, everything is closed and there isn't any options at the top to getting the toolbars back for auto cad for mac 2014. HELP? ASAP
maxim_k
in reply to: ElevatedRarity77
Welcome to the Autodesk Forums!
Have you tried to use CMD+1 shortcut or menu Window->Tool Sets to open Tool Sets palette?
Have you tried to reset palettes with menu Window->Reset Palettes?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
ElevatedRarity77
in reply to: maxim_k
Hi, i actually do not see any on the top buttons beside the AutoCAD 2014 name/button, so where the "window" button should be located, its just a blank space. The shortcut CMD+1 doesn't work for me or i might be pressing them wrong, I'm not too sure. As you can see from the picture, my tool palette is totally missing, how do i get that back? As well as the top main buttons where its blank in my above picture.
maxim_k
in reply to: jchumphries
Could you try the solution from this post (message #6):
http://forums.autodesk.com/t5/AutoCAD-for-Mac-General/Autocad-Lt-2013-app-store-download-no-menu-bar...
You need to substitute AC LT 2013 application and Library folders with appropriate AC 2014 folders.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
lichao.sun
I've tried reset palettes, it worked, thanks a lot!!!! 🙂
”Boost
