At the end of the Install message appears "INSTALLATION FAILED. The installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance." All files load and appear in finder however when I click to launch the application I get this message "You can’t open the application AutoCAD 2013.app because it may be damaged or incomplete." I have tried multiple times with both trial version and student version. Have also deleted all previous versions, reciepts, and library files. There was one instance when the install completed successfully however when I went to launch the application I got the same message again as when the installation failed. No idea what is wrong. Any help is appreciated, thanks.
Solved by mike. Go to Solution.
MAC OS X 10.9.5 trying to install autocad 2013 (free version for student) error: UNABLE TO OPEN THE FOLLOWING DISK IMAGES: DAMAGE IMAGE DATA
Someone can help me?
Thankyou
